Delll vostro 1015 plugged in not charging
Posted: Mon Oct 17, 2016 11:00 am
Laptop - Dell vostro 1015
Problem- plugged in not charging
Charging ic- max8731a
In bios it shows adapter type=65w and batery health = normal but 0%
Dcin- 19 volts
Acin- 3 volts above
Ac ok-3volts above
Scl,sda-3.3 volts
Psid-Ok
Dhi - 0.7 volt
Dlo -0volt
What could be the problem battery or in motherboard ???
Help please
Dcin- 19 volts
Acin- 3 volts above
Ac ok-3volts above
Scl,sda-3.3 volts
Psid-Ok
Dhi - 0.7 volt
Dlo -0volt
Help please
