Hi
i have this board from the above model , part number is 6-71-w24h0-d02a
it powers on but there is no backlight
i need schematic to see what voltage is missing from led screen connector
i check for fuse but there is no fuse near the connector
Clevo W7535 no backlight
Re: Clevo W7535 no backlight
remove the screen and check voltages on screen pcb ( vled, pwm and bl_on ) if you dont have schematic..!!
Back lit require generally 19Volts, Blon(Backliton) 3volts,PWM inverter again 3Volts. please check on screen pcb if do not have the schematics of laptop PCB.
Users browsing this forum: No registered users and 100 guests
